alphadeltaromeo
Diesel Enthusiast
First time poster here...hi there
Mangus580 referred me...
Anyway, just purchased a 1994 2500 6.5 2WD burb last night. Now, on to the issues, where I'm trusting I can get some good input to help me resolve the "challenges".
Overheating
Driving today and noticed after 30 mins that it began to overheat. Pull over and check the level in the overflow tank and it's dry. So, after about 45 mins of opening the valve on the manifold and pouring in 3 gallons (it puked probably 1/2-1 gallon out with all the air burping it out) I felt fairly comfy driving it. I watched the temp religiously through the day. It would hover about 190-200, but more to the 200 range.
What I found interesting was that with the overflow pressure cap off, it looked like it was steaming, but when I put my hand carefully over the "steam", it was rather cool. It apparently was more of a vapor. Any thoughts on what it may be? It took me about 45 mins mins as mentioned to get it fairly full of coolant.
Thoughts?
Stalling
So I've done quite a bit of reading up on the PMD. Previous owner told me he had the IP changed 2-3k miles ago. Coming home from work this evening (35 mile drive) it stalled 5 times. The burb would start to act like there was a fuel problem...jolting back and forth. If I pumped the peddle sometimes it would respond with the peddle and then other times it wouldn't for a few pumps, but then a few more it would respond. Then it would just die. I'd crank it and it would run fine for a few and then back to the same activity. I don't believe the PMD has had work...but while I know I need to get a new remote mount regardless, does the action reflect just a PMD issue or perhaps a lift pump or something else?
Thoughts?
Any input is greatly appreciated. I've had a merc diesel for some time, but never a 6.5. Thanks in advance!
Andy
Overheating
Thoughts?
Stalling
Thoughts?
Andy
