great white
Nope, 1500 is definitely NOT burning a hole in my pocket. I'd rather not spend it at all.
It's just waaay too expensive to order up a 4" exhaust gents, especially when I've got a perfectly good 3" system hanging int he rafters with a high flow muff and high flow cat. yes, I'm keeping the catalytic converter. As long as that sticker says "catalyst equipped" under the hood, it has to stay. Now, whether or not it's going to be and even more "straight though" design than it is now is yet to be determined....:rolleyes5:
Its the UPS shipping that's a killer.
3-400 for an exhaust and 3-400 to ship it after UPS screws ya to be around 6-800 bucks all in.
Besides, my 3" system is anything but restrictive and there was no "cutting corners" when it was fabbed. 3" is also the largest downpipe you can fit in there.
I'll be ordering up a 3 inch down pipe (can be had locally) and popping it on and mating my 3" system to it.
Kennedy only runs a 3.5 setup on his truck also. Well, last I read it was a 3.5, so not that big a diff.
At any rate, my 3" will be a lot less restrictive than what's on there right now.
I do my own OBDII tuning also.
Yup, you read that right right. I can flash my own OBDII programs into the PCM.....:devil:
All that and the WMI should keep the thing in check....
