Husker6.5
I know several have corn cobs up their asses, is that the same thing?Kind of makes one wonder how many in congress have corn investments as well as oil in their portfolio.
I suspect many of those corn cobs have electric cords attached to them too.I know several have corn cobs up their asses, is that the same thing?
isn't the tank zinc coated? seems i had flaking and looked zinc to me.Brass and BioDiesel don't get along. It turns green. You can't avoid the BioDiesel...
John Deere agrees... Brass, bronze, copper, lead, tin, and zinc can accelerate the oxidation of biodiesel and create deposits in the engine........
That could be likely.isn't the tank zinc coated? seems i had flaking and looked zinc to me.
if that's the case, all tanks will cause clogging over time. hopefully i'm wrong.
Nah, it's just because they're Fix Or Repair Daily, Failed On Race Day, Found On Road Dead, F*cking Old Recycled Dodges! Biodiesel didn't have anything to do with poor vendor Quality Control and the tank lining problems.That could be likely.
Can't remember the exact stretch. But a good 5 year or so run of ford's have had problems with the tanks delaminating. Likely from biodiesel.
Sent from my SAMSUNG-SM-G935A using Tapatalk
Oh yes, I fully realize that dynos are just a tuning tool, that get you a number. That's why I wanted one close by so once I had an idea of how mine acted on that particular dyno, it would help me determine the benefit of any future upgrades (it would be more apples-to-apples). They don't have the brand of the dyno listed, but it is a load cell dyno, not an inertia dyno. Here is what they list on their website. By the model number it's a Mustang dyno. The only thing I've heard about Mustang dynos is when I was reading Mustang (the car) magazines all the time - it was always said that they Mustang dynos gave a lower number, but it was supposed to be a more true number. Of course that was for that world, I'm not sure what that means for the turbo diesel world. They've only run 1 other diesel on it before. Regardless of the outcome, I'm still excited about the process, and I don't think it will be a total bust, I'll learn something from it either way.What type of dyno? Some dynos do not work well with diesels, and can either give really high numbers, or really low numbers. Straight inertia dynos tend to not do well with diesels as they don't load the engine up enough to fully spool the turbo. It's best to find a load cell dyno that can actually pull the engine down, load it, and control the acceleration as to accurately measure hp across the power band. Naturally aspirated engines are one thing to dyno, but forced induction is a completely different animal, and a forced induction diesel is yet another. And unless it's a true load cell dyno that can load it 100%, take the numbers with a grain of salt. Dynos can be great testing tools, but keep in mind it's still a testing tool.
Hmmm, are they high because the dyno is better able to load the engine and get the turbo spooled up really well....or are they high because it's a false reading? I'm guessing the former? I've read that people have tested on a Mustang dyno and then without any other changes hit a Dynojet and get a much higher number. That was for gasoline cars though so I'm not sure if that applies.Not sure on that one, but many with diesels have gotten really high numbers from mustang dynos.
Yup, that's exactly why I made the trans tune that won't downshift out of 3rd and keeps the converter locked - I wanted to take the variable of the torque converter out of the equation.
Gotcha. I know they have a lot of experience with boosted applications, but those are gas applications. I'll take as much video as I can and hopefully that will help tell the tale.Alot of it depends on the dyno operator. If they're not familiar with a boosted application, they can set the load incorrect allowing it to rev too quickly giving a false high. They'll set it so that it begins revving before it's on boost, then once the boost hits, it will rev really quickly. On the other hand, I read where some had low numbers because the operator would load it down too hard. Just have to make sure the operator knows what they're doing as that is what will make or break the numbers.
Engine dyno's are expensive & the best way to determine any and all results up/down 'great tool.'Once upon a time, I had access to an engine dyno, for free, 7 days a week. One of the 5 things I miss from that company.![]()
