steelydan
Looks like a nice install there. Why they bypass circuit?
I was running "questionable fuel" and still had the factory filter. It would allow to me switch over when it clogged and change the element when I pulled off the highway.
Them are nice jifaire, just what the dr ordered. Wher can I get them? What sizes are the fuel lines do you know off hand?
Look here, and click on Massachusetts, Matt. If you call one of these places, they should be able to tell ya where your closest retailer is.
Up here, I go to any Oilfield or Industrial parts supply store.. where you hang out, I have no clue where to look.
They are really pretty common.
You guys are 'way too serious... either that or I'm not serious enough.
Jim
You guys do realize this is the vacuum side of things so no psi to blow it off, and double flares, compression fitting while purty are overkill, I cut the tube, filed/sanded burs off cut tube, then slid hose over the tube, and 2 hose clamps each end of the hose/tube that didn't have barbs on it, and single clamp on barbed fitting
rubber hose and hose clamps
Hi Matt,
Take an inch or so of your hose and put it in a jar with some Diesel in it. If it's kinda gummy after sitting overnight........
Sock is clogging not making it to the filter
Now next time you drop the tank, let me know if the sock is blown off....
Mod correct spelling in this title please, and delete this message. It screws myself up searching for the mispelled word. I do know how to spell, perhaps I'm getting lazy with my old age.
