Fysh Guide
Fysh Guide
The Jesus nut is the great big one that holds the rotors on a helicopter and everyone goes Jesus I hope that nut stays on.
That's great!!
There were some crank manufacturers who said they would not honor the warrantee on their cranks if the Fluidampr was installed, but when I PMed a Fluidampr engineer, they said that the crank manufacturer had heard hearsay that the Fluidampr was causal in crank failure, but when Fluidampr contacted them to have that hypothesis tested, the crank manufacturer refused to test it, and so it remains as a 'Hearsay black mark' on Fluidampr reputation.
Right off the Fluidampr website;
8" 6.2/6.5 with electronic injector pump part #800141
8" 6.2 with mechanical injector pump part #800191
I just installed mine last week, OK, maybe 2 weeks ago. The only thing I can add to Packratts concise instructions is that when you go to start the new unit on, tap it on with a rubber hammer at the most. Don't use any sharp impact or force. At this point spin the puller (minus the smaller outside bolts) on the Jesus washer to press the fluidampr onto the spindle or mount or whatever it is called. The Jesus bolt (??, who came up with this term? I thought He was a carpenter, not a mechanic....) isn't quite long enough to press it initially but once the dampr is on a ways the bolt will reach. Don't forget the Jesus washer!
I was able to remove all the bolts and re-install them without removing the tranny inspection cover by using an impact on the Jesus nut and/or holding the counterweight/fluidampr with one hand and torquing with the other. This may not work for everyone. Blocking the tranny would be easier for torque settings and/or working without an impact gun.
It really is a handsomely made product. Nice workmanship, I don't know if the machined timing marks on the outside edge are functional but they look cool. As for what it's supposed to do, the long term will have to wait but the engine sure sounds better. Kinda like having a nice stereo loudly tuned into some tinny AM station and then taking off all that annoying treble and mid-range noise. All you have left is rumbling lows.
Yes I know:nopics:but I did it after work, 13 hours of plowing in a blizzard. I didn't have a camera. Sorry guys!
True enough.
Trust my life to the "Jesus nut" every day....
Thanks for the replies...still not sure what I will do yet. Is the fluidpnr made in America?
