Matt Bachand
Depends on the 6.5
Anyone running one of these and and comment about cost/effective?
Couldn't find any real - world posts on this site or other...
Shouldn't be any different than installing any other balancer and all tools should be in the loaner department at Autozone or equivalent.
- Remove serpentine belt.
- Likely need to remove fan shroud (upper and lower) 8mm socket (extension would be nice)
- Remove lower pulley from harmonic balancer, good time to replace this item also. 4 bolts 13mm or 15mm socket
- Remove Jesus bolt 15/16 or metric equivalent. If you don't have impact wrench need breaker bar. Also will need to remove access cover on bellhousing so someone can hold flywheel with BF screwdriver so crank doesn't turn.
- REMOVE BIG WASHER very important for next step, tried to pull balancer through washer one time, didn't work very good. :
- Attach harmonic balancer puller loaner tool
- Crank bolt with 3/4 socket until balancer comes off.
- Place new balancer on crankshaft.
- Tighten Jesus bolt and washer to 200 ft/lbs
- Put all the other crap back on.
