chrisk1500
- Messages
- 875
- Reaction score
- 1
Fuel rate at WARM idle with no accessories going (no DRL's, no radio, nothing) should be close to 10 mm^3 on a good IP...
Check to see if your IP has a filter harness on the optic sensor... this is NOT the same one as runs to the PMD.
It looks like this:
If it does, take the filter harness out and re-connect the wires - they just plug right inline.
If that solves your problem, then you probably don;t need to buy a new one - the OBD-II systems were supposed to have that filter built into the PCM - and can just run without one.
no, no hard starts, always cracks right off. no veggie, no bio, straight petroleum fuel, with stanadyne additive.
