bison
comparing the fuel line sizes to the 4 inlet holes is not to accurate IMO as the inlet orifice in the elbow as supplied by Leroy in his kit is only 1/4" wich in by my calculations is in area smaller than the combined area of the existing four 1/8" holes in the inlet tube,so the bottleneck is still right before the inlet,altough less so than with the stock barb.I aint disputing the FTB mode cause it will get the fuel there way less restricted than stock from the filter on.It does notting however for more flow trough the IP as the bores in the IP are just 3/16".Had this in my FTB thread, so I'm bringing it over
3/8" fuel line = .11 sq in
4 x 3/16 holes = .11 sq in
1/4" fuel line = .05 sq in
4 x 1/8 holes = .05 sq in
So you see there is a reason for boring the holes. You only want to restrict the flow at the final inlet point if possible, and have strong enough supply pressure to keep the whole thing happy.
but maybe i'm just rambling.nuttin new,happened before:smile 5:
