Acesneights1
It's handy to have around for doing tires too...
Brooklyn, you could do without the condescending attitude.
What pisses me off is when someone decides that they know everything
or have the right to make fun of someone else because they know better.
It's handy to have around for doing tires too...![]()
Talking about dangerous use of ether,this is worse than starting an engine on it.It could be deadly.I wasn't kidding. That is about all I do use it for. Beading stubborn tires. Which shows the force of exploding ether. It can blow a 44 in Ground Hawg onto a 14 inch wide rim and the tire jumps 2 ft off the ground. Imagine what that is doing to your engine.
I witnessed a fool once starting an old Olds 5.7 diesel using either.
He popped the hood and sprayed that beast down reeeeeeeeeeeeeeeeeal good.
His Missus whiped the starter over and the thing took into orbit. OMG the poor little thing was screaming.
TD,
It is a known fact that even one use of ether usually wipes the glow plugs.
Perhaps a technical description of why the ether wipes the glows. I know it happens but was at a loss to explain excatly why .
AUTOGUARD PREMIUM STARTING FLUID
Engine starting fluids are aerosol products which sprayed into the carburetor or attached to an injection system, will assist starting engines which may be balky due to cold, dampness or under maintenance. Typically starting fluids consist of ethyl ether, blended with other petroleum hydrocarbon. How well a product dispenses the ether in cold weather is an important characteristic. AUTOGUARD
Starting Fluids are effective down to -65˚F, they have low freeze points, high vapor pressure at low temperatures, low flash point, high BTU content and an upper cylinder lubricant for protection. AUTOGUARD Starting Fluid may be used with gasoline engines and some diesel engines. It is not recommended using any starting fluid in diesel engines that have glow plugs. Most passenger car and light truck diesel engines have glow plugs in order to preheat the combustion chamber. The use of starting fluid in engines with glow plugs can cause serious engine damage and possible personal injury. Larger trucks and tractors may not have glow plugs. For example, some tractors do not have glow plugs and inject starting fluid directly into the manifold. Starting fluid works very well in this type of application.
Always consult the owner's manual to determine the manufacturer's recommendation and whether or not a specific vehicle is equipped with glow plugs. Follow the directions on the can when using any of AUTOGUARD Starting Fluids.
Yeah but a tire don't cost 8000$ if you damage it. It's not the method of choice but sometimes when the Cheetah don't work it's the only way.
BTW Disclaimer: Using ether to bead tires is extremely dangerous and seriuo injury or death may occur. This should only be attempted by experienced people. Don't try this at home !!
I'm sorry to hear that. Like I said no doubt a bad way to do it. Usually means the rim is damaged if the cheetah won't work. I'm real careful. I usually put on my welding gear and use a long stick to light it.Even experienced people can die from this practice. My cousin did...
Bill
