gahammerle
Saved by God's grace
I put the tranny in gear and turned key to start - heard the lift pump. The added relay was wired the same as in the thread here with the exception of getting power from the post on the underhood fuse/relay box instead of from the wire going to the OPS. The OPS's gray was cut with both ends terminating in the relay.
No bio or wvo. Just diesel #2 & Diesel Kleen.
TDCO is -0.79
IP Timing fluctuated between 16 and 20.
TDCO is -0.79
