- Staff
- #41
Shoot, I only have about an 1/8" of clearance on mine all the way around. And it has yet to bump even with the DMAX twisting it up there.
Is the Heath clutch a hayden?
Hey finally got to look up the clutch. My Hayen Book shows a 2831 as the Severe Duty Clutch for the 4 bolt 6.5 rev rot . That # should cross directly to NAPA.
Thanks Kenny,
Does the book give any details, as to when it engauges? (sp)
been wanting to do the fan clutch mod, want to do it this season before towing the camper. think I should try it with my stock fan first, or do the dmax fan at the same time? I'm also thinking about doing the hb, as it's never been done. Maybe I should do them all at once, make a day of it?
The whole point of this thread is to get rid of the stock fan with the 6 bolts and get a better 9 blade steel or 'suck the birds off the road in front of you' Duramax fan. That number looks like a old 6 bolt fan setup... :sick:
The 170 degree turn on temp and lower than stock lock up temps help with AC performance on gassers. I have experienced this myself. Diesel I can't say.
From their site:
"Engages at about 170° radiator air temperature, (about 30° lower than coolant temperature). "
"Some Chevrolet/GMC truck models are specifically designed to engage at lower temperatures than the original equipment parts that they replace. "
http://www.haydenauto.com/Featured Products-Fan Clutches and Fan Blades/Content.aspx
Would have done the fan clutch mod today if I could find my fancy wrench to hold the hub. Last I remember my 4 y.o. had a hold of it. No telling where it is now.
I used a not so fancy screwdriver behind the studs. My 5 & 6 year old took my jack, jacked up a battery-operated Jeep and crawled under it with some of my tools. Not sure what they were trying to fix, but they like to do that when I'm working on my truck.
That is so funny. My 4yr old does excatly the same thing. I bought him one of the 20$ Jap Jacks to play with cause he was gonna get hurt trying to move my 3 ton lincoln around.
