Duramax Fan p/n 15010202
Matt Bachand
Depends on the 6.5
Worcester, MA
After seeing how much airflow at idle the D-Max fan throws out, compared to stocker. I decided I want this fan, even though my clutch is modded perfectly, and I have no overheat issues.
What year D-Max's is this fan for?
Rockauto has it for 40 bux for the 2002 year. Any specific models I should search for?
Anyone know the latest rockauto discount codE?
Thanks!
GM Part # 15010202 All the D-Max Fans are compositie right?
I checked the vendors, nobody sells just the fan. Seems like GM or junkyard.
Bills price for the Fan and clutch is about what you'd pay trying to put it together yourself. The HD clutch is 150$ alone. I didn't bother cause I only changed my clutch but if you want the Dmax fan it's probably better to just buy Bill's.
I want to use my current clutch which I adjusted and is perfect to my liking.
Ha! Nice Avatar Kenny!
Run of bad luck...TD, MAtt and Bill got to witness first hand how bad things unexplained things just happen to me. I suppose it keeps me on my toes diagnostics wise.
The DURAMAX fan from a 01-04.5 engine should bolt right up to a 6.5 fan clutch. I know the DMAX fan that I had on my 6.5 fan clutch is the same one that is now bolted up to my DMAX fan clutch as my DMAX fan had a broken blade on it.
Hmmm, if it's an easy bolt on maybe I'll have to do it. I still havent done the fan clutch mod, I'd like to but it's just too far down the list of things I can't get around to.
