oldtoyboyd
It is the factory version of the 2839
I used the ACDELCO 12T45E which is apparently made by motorad.
( I called mototrad and asked if they made the tstat as It didn't have any hint of GM on it, and they said they make for GM).
Thats a bunch of BS if you ask me.....Delco comes in a Delco box. NEVER heard of "motorad
Okay The 190 Seems to be working properly. It looks like the oem stat....
The one that buddy recommended did not work well, it was going up to 210F,
and was supposed to be 195....Maybe It was for a dual stat setup (I don't Know).
I'm Thinking that if I found a 195F stat that is similar to the OEM and kennedy's it would work better...I have to find one and see.
I took some Pictures (not any of Kennedy's Stat...was a afterthought).
This was the one that didn't work...was seeing up to 210F with this stat
This was the 15Yr old OEM one GM old Part#12551496 (still worked)
This was the Box from Kennedy's 190 Stat (when I find a 195 Ill take a picture of this stat)
Looks Like Robertshaw is partnered up with Prestone.
Prestone is listing it for our truck http://www.cadna.com/Catalogs/Prestone_Thermostat_2006_Catalog.pdf
Do the Delco and the RS physically look the same?
