robzombie4551
robzombie4551
what won't fit?
So did anyone get the right clutch to fit?
I just ordered a 1580690 fan blade ( 9 blade plastic) and have a 6 bolt stock clutch and water pump.
I figured after 80k miles it might also be time to change the fan clutch...and I was wondering what worked? Also if/and when my water pump goes out....am I gonna have to get a different fan clutch?
I have some confusion about the newer better 99 and up pump not mating to the fan clutch...something about threaded verses not?
Or should I just keep on using the stock clutch ( 6 bolt) with the new fan blade when It arrives?
I'm a little Confused...and what won't fit Veg_out?
Severe duty is what you want
Link: http://www.haydenauto.com/Featured Products-Fan Clutches and Fan Blades/Content.aspx
Did you try the spring mod handcannon?
Said it before, I tryed every combo......and the D Max fan made a world of difference.
That sucker moves a lot of air!
I also saw another ...dont know if its right Hayden 2831
I used an acdelco 15-4674 fan clutch from amazon. I paid a little over 70 bucks for it. Then I got a Duramax fan and mounted it up. Put in the correct delco thermostat and it's been perfect ever since. Works good in Mississippi.
