great white
When I ordered my kit it was 389 + shipping.
The blue hose is blue simply because it from Eaton. I've got the same hose in black from other suppliers.
It is 1/2".
The pump also comes with the push lock fittings and some wiring.
It's enough to run your own system from tank to FM. You need a but more if you're going to run a prefilter anywhere besides right in line with the run. Mine is over to the side under the bed which necessitated a bit of extra length:
I added some fittings and extra length, relays and wiring because...well, I've been called a perfectionist more than once.....
You also will need to find a way to connect the 1/2" push lok hose to the filter manager. I drilled it out and tapped it for a fitting:
I also took the opportunity to do ftb ver 2.0 while I was in there.
I run mine at 12-15 psi. You don't want to go any higher on a ds4. My pressure, doesn't drop much more than a couple psi at wot.
My stock fuel system was in good shape, but I ripped it all out because I wanted better.
Next up is a sump with 1/2" feed for the tank.
Now, time for a reality check:
1/2" feed line and a raptor pump is complete and total over kill for a 6.5.
ANY 6.5, mild or wild.
These things were built to feed far more GPH/HP than our engines could ever hope to make.
But I like what I like and I'm going to get it!
You have to decide if that's reason enough for you to pony up the extra dough....
It is 1/2".
![DSC04082.jpg](http://i40.photobucket.com/albums/e235/gr8twhite/1998%20GMC/fuel/DSC04082.jpg)
![DSC04063.jpg](http://i40.photobucket.com/albums/e235/gr8twhite/1998%20GMC/fuel/DSC04063.jpg)
![DSC04065.jpg](http://i40.photobucket.com/albums/e235/gr8twhite/1998%20GMC/fuel/DSC04065.jpg)
![DSC04069.jpg](http://i40.photobucket.com/albums/e235/gr8twhite/1998%20GMC/fuel/DSC04069.jpg)
![DSC04070.jpg](http://i40.photobucket.com/albums/e235/gr8twhite/1998%20GMC/fuel/DSC04070.jpg)
![DSC04076.jpg](http://i40.photobucket.com/albums/e235/gr8twhite/1998%20GMC/fuel/DSC04076.jpg)
