schiker
Does this white crush ring wear out or have some issues depending????
With bad lift pump would the vacuum in the first few chambers be high and stress the little white "crush ring" making it deform back and forth more than normal such that it might deteriorate the transfer pumps ability to maintain expected psi and flowrate ?????
Really high Lift pump pressure might blow out this white crush ring. And increase houisng pressure significantly but the expected differential to charge pressure might get screwy ??? I don't know what all happens.
But lift pump pressure of up to about 15 psi seems to just help ensure complete fill and slightly increase charge pressure due to better transfer pump operation and increases slightly the throughput of diesel through the IP.
