buddy
Active Member
You got that right Matt, more pressure for same time is more flow than PCM knows. If someone figured out how to reliably regulate the pressure higher then it would be a pretty sweet modification.
DS4 will idle fine and cruise fine, but you wouldnt be doing this mod if you were concerned about driveability. Its also easy enough to change the fuel curve to desensitize the pedal. May be one of those things that needs to come with its own customized PCM program.
