I've done a ton of them over the years, reg hydraulic jack under middle of door,, 2ft pry bar pop spring out,, hit pin's on small side with air chisel bit,, ,, that was broken and had the fut hacked off it years ago, pop those pins on the ends,, knocks knurled heats out of holes,, then pull out with vice grips clamped under the head tapped out with hammer. Tape on door and fender,, lean door carefully against fender, press in new bushings using vice grips with small spoon, then gently tap in the rest of the way,,, line up door, slide pins in and tap and set head of pins. Don't forget the locks on the pins.
