FellowTraveler
I've had to do this too on a few GMT400's I have owned.That's an old carpenter's trick.
I only use dealer bushings anymore(been a mechanic for 24 years). I have had same problem with aftermarket bushings breaking trying to install them. Never broke a dealer one. Also on your door rattle, do you mean when you hit a big pothole or something you get that thump from the door like it bounces up and down? If so, mine quit doing that after I changed both door weatherstrippings.
Last resort is Dorman. Otherwise a dealership or LMC. Also, if the pins are worn, there is a good chance that the latch is also worn and/or the mounting screws have loosened slightly.Striker pins are worn. Where do you get new ones?
I would revisit @1999gmc comment about weather stripping. Our climates dry rot it badly and it is the shock adsorber for the door. You would be amazed at how much tighter it makes the doors with new GM weatherstripping. I have to slam my doors with new weatherstripping. Be prepared to spend $$$ as they are proud of them... of course it was the last thing I thought about after replacing pins, latches and the striker including adjustment. I did all the doors, the tailgate, and the strip under the hood to the cowl on our burb. The doors take the main strip and then a upper strip - they always need both done.
It's one of the best immediate improvement things I do to vehicles.
