TurboTahoe
Recruit
- Messages
- 790
- Reaction score
- 6
I agree with the guys, that's not a bad list.
I have two 6.5s, and my list looks like this:
Actually, the list goes on a bit from there, but you get the idea.. There are a LOT of things that just wear out on these things, and some of them aren't the most well designed or manufactured (sorry, but it's true). On the other hand, I've driven around 85K miles on both rigs with very few problems, thanks to the guys on this forum, and I've done almost all the work myself. I know that if I had purchased the Tahoe and Burb new, I'd probably have less personal work on them (i.e. hours of my personal wrenching, although I suspect with GM quality control I'd probably be in for warranty service more often...), but they have been pretty cheap to keep, and if you do the work yourself, the guys are exactly right - this is a decent shade-tree mechanic's rig. Looking at the list I just made, I think that many of these items just wore out due to the rigs being 12 and 16 years old respectively, with 110K and 185K miles on the Burb and Tahoe respectively. That's a lot of miles.
They are getting old, that's for sure... they are also inexpensive to own (unless diesel goes to $5/gallon, which is probable) and run, and they get the job done.
I hear you, it is a bit of a hassle, but I really like my rigs, and they have been fairly dependable and they work hard and always get my family to and fro safely.
I just want to encourage you to hang in there and just stay with it - I'd found that the journey has been fruitful and pretty easy, and usually fun... just hang with your 6.5 family. We're here.
-Rob
- New front brakes, both vehicles
- New batteries, both vehicles
- New PMDs and remote mounts, both vehicles
- New glow plugs, Tahoe
- New heater blower motor, Tahoe
- New 4WD switch, Burb
- New headlamp switch, Tahoe
- New turbo solenoid, both rigs
- New EGR Solenoid, Tahoe
- New vacuum turbo solenoid harness, Burb
- New OPS (x2) on the Tahoe.
- New Remote OPS relay bypass on Tahoe
- New LP both rigs
- New LP relay, Burb
- New MAP sensor, Burb
- New Glow Controller, Tahoe
- New coolant QC replacements, both rigs
- New sway bars, both rigs
- New pitman arms, both rigs
- New upper ball joints, Tahoe
- New shocks all around, Tahoe
- New electric fans, Tahoe
- New Fan controller, Tahoe
- New air cleaner assembly, Tahoe
- New heater/ac fan controller control (x2), Burb
- New power door lock solenoids (x4), Burb
- New door handle, Burb
- New steering end links and idler arm, Tahoe
- New air compressor (for air horn
), Tahoe
-Rob
