- Staff
- #181
did you do a comparison between 2 files? if you did they need to be the same type of file to get the differences, A stock file compared to a mod file, or comparing the different addressess?
The firmware is mapped to about 92mm3 but capped at 80mm3 I believe. There's room to rewrite and get more fuel out, to maybe 110 or 120 mm3. Just need time to figure it out.
There is a little more stuff to be put in the files, just need more time and energy. I'll post another XDF that is for an updated bin that's not compatible ( alot of differences ) with the original XDF's. I need to finish it for others to use. ( I only put in it what I wanted )
Yes, I compared 2 tune files of the same type and was getting lines that were different. What is wierd is one of teh comparisons was of a tune file that thedrip made to the stock file he used and it is coming up with sections changed that aren't mapped. ANd one of teh files I made did the same thing. It looks like some files we can change are changing other files we can't see(right now). The extra fueling would be pretty important to get to(at least up to about 95mm3 of fuel).
