bobbiemartin
Author of The DB2 Conversion Guide
I tried every way possible to synch up the original APP to the cable. Had slotted arms, adjustable rods, never could get it to work right. Hard 1-2 shifts mostly, if that worked, then something else didn't. Factory TCM can be had pretty cheaply, everything works as it should. On 2WD, its very easy. If you got it to work, then that is great. My experience is most people can't. In any event, I Love the DB2, almost 8 years and about 100,000 miles if I remember correctly when I did the conversion. It's great not having PCM worries.
