Larry
Does anybody know the best place to get heads
.Mine are cracked,between the valves and I have a bent intake valve on # 8 cylinder.Thank you.
Larry
Larry
I think I have been fair about my assessment of these heads. The cup material is inferior IMO, and the cups weren't machined for a proper fit. The casting is a bit rough as well. OTOH, there are no gross flaws in the casting, and the seat machining appears to be quite good. I threw an intake gasket on them today, and the ports actually match up as good as the GM heads. Also, closer inspection revealed that there IS more metal in the deck area. I still need to measure the guide clearance, but judging by the fit of the valve stems I think they are fine.
