Meatman
My other vehicle has 2 Turbos!
looks like the resistor gets pushed/pluged into the new PMD.
Correct?
But which way?
Correct?
But which way?
But which way is correct?
Hello everyone....
I just bought a 94 GMC 2500 with a 6.5 TD (166K Kms), and I am going through the required maintenance when you first buy a vehicle. Such as all the filters/fluids, a new set of glow plugs (duraterms).
This is my first diesel and I have yet to buy a service manual so I am unsure on a few things.
When I replace my fuel filter (engine bay) is it as simple as it looks? Just unscrew the used filter, screw on the new one, crack the bleed valve on the top (little black part) turn the key to the on position and when the diesel starts to come out tighten the valve and that's it?
Second question is I have owned it for a few weeks and an issue has arisen where after driving it for ~1/2 hour it just dies.... however it restarts every time. Its kinda random, happens 3 X in a row then not for 1/2 hr..... then again.....very intermittent. Its kinda like when you shut the truck off by taking the key out....immediate dead... no stumble just dead.
Is this the PMD failure I have read about ( I have read for about 10 hours before I posted anything)? It is a Stanadyne PMD still located on the IP. I was told by the previous owner that the IP was replaced about 1.5 years ago (20K Kms). When the IP gets replaced does the shop usually transfer over the PMD or does the IP come with a new one?
As well I am planning on getting a remote PMD (what is the other term FMD?) with the heat sink asap.
Correct?
But which way?
So why not put all the new info you got into your sig?Hello again..... So now I am getting into some hauling of trailers.
As it is right now it is pretty much stock (performance wise) except a 4" exhaust. It had the HD suspension and rear brakes (I decoded the vin).
What is the towing capacity of a vehicly like mine? And so noone has to go re-read the thread it is a 1994 GMC 6.5 turbo diesel with a 3.73 rear end (IIRC).
I did think of that, and I did try to update it.... however when I signed up I barely figured out how to do it. This time I didn't figure it out.... got to frustrated!![]()
