Cooper Discoverer A/T 3
I run 75 psi when towing and I run 58 psi when unloaded around town. Anything more than that knocks my fillings in my teeth loose.
Maybe your roads are different, but when I run 80 psi all the way around, and hit a small bump or pothole, it sounds like the front end is falling out. I personally get a much better, quieter ride when I run 58 psi. I have experimented extensively.
On my srw I agree with lower psi.
I just rotated on my dually at 9k miles, the fronts have an almost full contact pattern when aired to 80 and put on the rear. 235/80 17's
Tanner, how low on the SRW? I'm curious if anyone else runs lower than 55 psi, I'd never run across that before. I won't run lower, but curious anyway.
On my 95 K1500 I ran low 40's out back and 50ish front on 265/75 16's
On my 06 LBZ w/ 305/55 20's E rating 65psi max rating I would run as low as 50psi on Cooper AT3'S up front and St Maxx in the rears both 3ply sidewall tires.
The light duty (7.2k GVWR) K2500 Burb placard shows 40 psi front & 50 psi back, the K2500 (8.6k+) placard shows 55 front & 80 rear.
I've run 40 psi on these 295/75/16 e TOYO's and it gets soft cushy ride w/o over heating sidewalls.
New tires! Replaced the worn out 245's with 265/75-16's.
Look good, calibrate the VSSB & ABS controller, or?
No, I don't plan to. It's only about a 4% difference in circumference. My truck since I've had it has a speedo error issue anyway, though when I read speed through the OBDII it reads out correctly so I think my odometer has been accurate. The speedo has read about 22% higher than actual speed, so when I'm going 60 the speedo reads 73 or so. Not sure what is going on with that but I've just lived with it.
I don't have a tuner. I did check some time ago with GPS, then got one of those bluetooth OBDII plugs so I could see speed on my phone. The OBDII speed reading matches the GPS speed, while the speedo reads much higher.
