Functionally, all of them are the same from 94+, only 91-93 had the odd ball pressure control solenoid. It's not like the 4l60e where GM was constantly changing them, even going so far as to have 6+ different models in a single model year. There's differences like 94 to 95 where the shift linkage changed(for pickups, but other variants changed at different times), the cooler lines changed in 97, and some other running changes. But functionally, they remained constant to my knowledge from 94+.@THEFERMANATOR
Not to be rude and step on his thread. But my Hummer has db2 and GM tcm controlling it. Is it just install the 4l85e inplace of the 4l80e? Or is there programming, etc needing to be done for the 06 van trans?
Does your Humvee use the GM transfer case? If so, you'll have to disassemble the van 4L85E transmission in order to swap out the output shaft from 2WD to 4WD and the rear case. If it's a divorced T-case then the 4L85E is a bolt-in. I do NOT know about harness end compatibilities, you may have to swap the transmission harness/connector.@THEFERMANATOR
What, you haven't busted one of those yet? How could you not claim grenading one of those in all your year of machine abuse? LOL!Forgot about the hollow shaft snapping TCC locked issue... With the Yank and TC override switch I need to upgrade that.
