Cold Air Intake: My version
mfgguru
Makin' it better!
Winkler, MB, Canada
Hey everyone. Felt ambitious this week, and decided to build myself a "true" cold air intake, not just an elbow with a filter on it. I teach introductory sheet metal, so I have access to some tools that make life little easier on a project like this. I had to flatten the top of the fender well to get the battery to sit down a bit lower, but seems to be a good fit, need to build a proper battery mount yet. Chicago TDP did something like this back on the "place" some time ago, but I couldn't find pictures from that thread, so I decided to do my own version. Let me know what you think, and if I could make some improvements.
quite a job,looks OK.
you still seem to have room for underhood air to get in on the top front.Altough it looks you designed it like that.
I'm planning to box in the area between the bat and rad support from the fender to the rad,top to bottom ,and open up the fender inlet slot some more.
looks good! I've been wanting to do that for some time now I just havent quite had the time. I also spentquite a bit of time redoing the battery interface so thats also stopping me from doing an intake behind the light.
While driving, it will scoop air that flows between the hood and grill, not too worried about hot air up front while the truck is moving.
Nice work! If you really want to move more air in that thing, replace the turn signal lamp with expanded metal and paint it yellow so that the light bulb still works, just doesn't have a reflector. That will let it get lots more cold air.
Nice looking setup, I'd put a different filter on it, but I'm not one of those only paper 0.0000000000000000000000000000000000001 micron filter guys.
x2 I was gonna set mine up like that. I still may someday with the cummins.
It would take balls, but would be cool if that sealed around the hood, where an actual scoop was. Could throw another one on the other side with some direction louvers inside it to direct fresh/cold air right on top of the engine.
Nice very Nice all i do was this !
Mike
photos:
Nope i actually lost 1 oil leak by Ripping the POS off.
I run SAE60 AMSOIL synthetic oil so the unless its a major leak i doubt i'll ever notice it.
The breather is all of $9.99 n always in stock so i'll just change it very other oil change or so n should never have any problems with it :D !
they only cause leaks when you let'em plug up. . .
Mike
nice intake mfgguru, pretty much same thing I want to do, although my plan to start was just moving the battery and having filter right behind the lights. If I were to ever notice an IAT issue, then box it in.
