Will L.
His recommendation of using it, especially doubled up, is just pushin all in. Question is, are ya lucky? Law of averages
What should the oil pressure read at hot idle?As your oil warms up it will be thinner and your gauge will show less pressure. Hot oil pressure at idle is the number to be concerned about.
The filter is wix and the oil is shell rotella t5 synthetic 15w-40.Can’t id the noise. The occasional no oil pressure hot is big concern.
Pull the belt to reduce noise for narrowing it down closer, just dont run for a full minute. Then put it back on and restart to cycle coolant through. Need a mechanics stethoscope on there. My WAG is lifter to rocker arm noise from lifter not pumping up.
I would really want to put a real oil gauge port where turbo is feed from. This is the end of the line of oil circuit, therefore lowest pressure and volume point. If not there then the rear diagonal opposite location.
What filter and oil brand and weight are you running?
I was wondering if it could be the gauge, because when I fill up the fuel it goes way past the F.Mine idols hot at about 30 PSI... On the highway usually around 50 55 PSI. .but we all have to remember there's a lot of room for error there because GM gauges are not exactly reliable.
