buddy
Active Member
They won't rub i have my t- bars turned up like 4 or 5 turns and i'm running 35's no rubbin even with flex
John are those stock 16" rims with 0 offset?
275/55/20 are slightly wider and a tad taller than 265/75/16, but close.
The first number is width in mm, second is ratio of width to wall height, so multiply first number by the decimal of the second, multiply that by 2, and add last to get the theoretical tire height in mm. divide by 25.4 to get inches. Installed height is usually about 1/2 to 1 inch shorter though.
