Crankme69 just put 275/55/20s in his 95 C1500 and they rubbed some and would hit the fender when suspension traveled.
However his wheels are 0 offset, just like the factory wheels I think. Your wheels will be wider and taller, so I think you'll have more issues. The rubbing would probably been solved with -12mm offset (1/2") or maybe even just some 1/4" wheel spacers. Some coil spacers will solve the suspension travel issue. When putting that big of wheels on you typically need negative offset wheels or spacers, and some type of suspension lift, but your 4x4 likely has some more lift than a 2WD.
You will also take a LOT of torque away that you can put to the ground, and dont think youll like the result.
