handcannon
1) No, he used the knuckles from the 2000 to 2008 2500 HD in place of the knuckles on the 98.
2) The way the spindle is set up on our trucks is somewhat like a front wheel drive vehicle. The spindle is a flat plate with a hole in the center. The ball joints go in protrusions on each end of the plate. The axle shaft goes through the hole in the center of the spindle. When you say steering knuckle I think of the knuckle on each end of a solid steering axle, which is very different from the spindle on an independent suspension front drive axle.
3) This part took me a while to visualize what he was describing. I finally figured it out. He made an adapter, like a piece of threaded rod. Only, it had threads to match the 98 trucks tie rod on one end and threads to match the newer DMax tie rod on the other end. This then threaded into the newer DMax tie rod on one end, and into the 98 tie rod on the other end, coupling the new and old tie rods together. Doing it this way leaves the stock 98 truck adjuster sleeve in working condition and allowing for tie rod length adjustment.
I have the spindle and tie rod ends out of an 02 DMax to use. I still need to have the tie rod adapter made, and modify the spindle so the older truck ball joints will fit. I had hoped to have this all done by now, but I've been too busy this past summer. So now I'll need to do this over the winter.
It may take me a while to do this, but I'll try to take a lot of pics when I finally get around to doing the brake mod.
Don
Don
