It’s almost comical that I suggest this because a ‘fix in a can’ has always been what I made fun of. But every independent test has shown this stuff helps and hasn’t harmed any engine with 100,000 miles on it. I wouldn’t put it in anything less because it could build up in tight tolerance where you don’t want it maybe. It’s called:
“Restore”
Engine restore and lube
Engine Restorer
RESTORE Engine Restorer is the only product proven to repair worn cylinders and restore compression back to near original levels.www.restoreusa.com
Thanks, I was thinking dry meant not allowing any fuel or oil into the cylinders and disable the glow plug power while cranking. just wasn't sure if the proper way was pull all the glows out first to allow it to spin freeier (no compression stroke for other cylinders) or leave them in.Pull all the glow plugs and your test will be dry as in don't squirt any oil in the cylinders. It could fire from the oil
we might have you do diagnostic on one or kore cylinders.
@Big T :My friend, ya need help.
I put a can in each of my Toyotas, and one in my son’s dodge. I can’t say anything positive or negative from my usage. But there is a bunch of folks that had positive results from it.
Here is some basic testing worth watching:
