Let me describe the scene... Used the vehicle for approximately 60 miles on a warm day with several shut down stops. After the last stop (approx. 10 mins.). Vehicle would not start (turns over, but won't start). After about 10-15 mins. and 5-6 start attempts, vehicle started, and I drove 30 miles to the house. I have a fuel pressure gauge installed, and while attempting to start the vehicle, I had 10psi each time. Also, no codes "popped". However, while driving back to the house, I did get a little bouncing on the needle on the fuel pressure gauge. I got to the house, shut down, and waited a few mins., and then tried to start. It started every time like normal.
My remedy was to swap out my extra PMD onto my bumper mounted kit, and change my fuel filters (one in the stock fuel unit and one mounted after the tank on the side rail and before the Carter fuel pump, as well as check my grounds (clean and tight).
Few days passed. Went to start the vehicle, and it started right up. I drove five miles to the store. Shut down. I was in the store 10-15 mins. Came out. Went to start the vehicle...no start (turns over, but no start, solid fuel pressure). After 5-6 attempts, the vehicle started, and I drove to the house. Shut down, and waited 10-15 mins. Attempted to start, and it started right up like normal.
Here is a possible pattern I see. Truck starts fine for 5-6 starts, then will not start for 5-6 attempts, and then starts...?
I have many modifications on this vehicle. Basically, everything they say to make this a reliable vehicle. But, here we go again.
Has anyone had similar symptoms...? If so, how'd you fix it?
