Husker6.5
You don't. It's a custom built unit that @ak diesel driver makes.@ak diesel driver Electroviscous clutch? Where do I find specs on that?
After all the testing and documentation, isn't it generally understood that if your stock gauge reads 210, it's too late. There are pockets in the heads that have already gone into "the danger zone" and possibly are being damaged. Evans waterless coolant helps prevent the hot spots, but I've found it's a little impractical for me, and the cost doesn't help me at all. I had switched over back when I was making good money, but those days are long gone and any water in the system starts to negate the benefits. Do the things War Wagon says.
Our motors are, at best, compromises of cost savings and engineering.
IMO after use on the "not anywhere near stock" 2003 5.9 Cummins: the 6.5TD simply doesn't have enough room in the cooling system for the reduced BTU capability of the Evans. This would maybe change if you coated things to keep the heat out of the cooling system.
I forget I ran the 2 bottles of water wetter. (diesel systems are so big they need 2. Read the label as this dose may have changed.) I will have to pick some up for the new pickup now...
I have a 93 6.5 I have upgraded to 180+ gallons a minute water pump Duramax fan 180° thermostat single. What is the cost to replace the radiator the ceramic version. Thank you for any advice and help you may land respectfully harryIf you replace the radiator I offer 3 row aluminum units that I apply a ceramic thermal dispersant coating to to enable 33% more heat dissipation than bare aluminum..
Thank you sir;Sorry, I don't stock a unit for the 93, I must have overlooked the year of your truck.. I can coat one if you have it sent here if you decide to go that way.. I don't do copper/brass soldered radiators any longer..
Pretty sure from his other posts he has the 97-99 style ho pump.If you've upgraded to the model year 2000+ Balanced Flow water pump with the spin on fan clutch (with lo-temp kick-in modification or Kennedy Diesel's lo-temp fan clutch) and a D-Max fan - you've basically gotten the maximum bang for the buck for cooling modifications - especially if you've removed/relocated the the A/C evaporator and the other coolers.
You have another option. Kennedy’s clutch was the go to and is proven well.Thankyou I will purchase the Kennedy when I get her home
