79jasper
Active Member
I use steel bb's. Lol cheaper than the actual beads, and seem to work the same.
Sent from my SAMSUNG-SM-G935A using Tapatalk
I used beads from a company called Mohawk Rubber. That's all I can remember at the moment. My Alzheimers is kicking in a little early. LOLDo you happen to remember which beads you used? Thinking about putting some beads in mine when I pull the tire to clean the rim(my PYO'S corroded on the bead, and leak since I put new tires on).
I just sold about 40# of lead shot to a Black Powder shooter last summer. Wished I had thought of this.I use steel bb's. Lol cheaper than the actual beads, and seem to work the same.
OK, thanks.I am out of my house right now. I will check when I get back. Generally a tire that big would require about 4 to 5 ozs.
Maybe more like TriggerHopefully I'm at least entertaining like Roy Rogers side kick Pat.
I checked the charts that I have. It shows 5oz per tire for your size.235/85/16's ?
