buddy
Active Member
The intake temps are lower with an ATT, but I wouldnt call them low in the mid 200s under sustained boost. For every 1 degree you cool the intake air, the cylinder temp will be decreased 3 degrees (because of compression). The reason an intercooler would be good is because you have a non-wastegated turbo, so cannot control max boost. An intercooler will lower your boost at the same amount of spooling, because it will make the same amount of air more compact when colder. So it will help lower your boost if was getting high, and the higher the boost the more heat the turbo transfers to the intake air charge. Intercoolers are a safer way to get more air mass without more air pressure.
