Turbine Doc
Just Another Diesel Guy
BW with a 95 I'll surmise you could do away with your vac pump and install a TM, your truck a S engine 8th VIN digit ???
casperselectronics.com check out their stuff. far better than these home made things you buy on e*** . i bought the pins and connectors and made my on out of much larger guage wire. remember the fuel solenoid draws a lot of current, and i also ran a seperate grd wire from the heat sink back to the ip grd point. the wire in some of these e*** cables are way to small and can not handle the current. cause the connections to over heat and you are walking!
A thermal pad does not insulate, as its entire purpose is to conduct heat. And it does a pretty bad job at it usually which is why they shouldnt be used.
buddy said:Running the cable back to the IP would be to prevent an electric potential difference in grounds.
FWIW my PMD has been grounded to same engine bolt as my D.S. Battery. Took it off PMD when installing SS-DIESELs crap kit, and ended up putting it there 2 years ago mid winter when I bought my Heath. No issues. No codes. 2 years.
There are still people running the original PMD on the pump with no trouble too,
but they are the exception, as are you :smile5:
