NVW
I don't believe our trucks have an O2 sensor. Leo
Uh, guys? We have a vendor on this site that sells extension cables... Leroy's price is good, warranty is from a 6.5 guy we know, so if you're just buying an extension, let's support him if you can, OK?
www.pmdcable.com
Given the number of issues people have had with Edam from Quebec, it's amazing that this keeps coming up.
A used PMD is a used PMD.
You guys remember that line on Tommy Boy, something about slapping a warranty on a turd in a box.........not that Heaths is a turd, just made me think of it. Does Heath do something to weatherize it and it comes all put together?
Well of you get it running take it to the local garage and have them check the oxygen sensor. The oxygen sensor is the most replaced electrical part of most diesel trucks.
No O2 sensor. That is gasser, my Camry has 2 O2 sensors. They are still good after almost 160K.
The objective of diesel it to produces Nitrogen and Oxide. Just kidding.
I put my original PMD in and it started,ran for 15 mi and quit,very hot. E*** Pmd works, Pmd with used IP works.
Old IP turns about 40 Degrees and jams,maybe let go???
ext cable 4 of 6 pins dont work
took truck for a spin, lots of black smoke
codes 18, 32, 33
I need to have the timing set (18?)
His price is competitive, and I would probably have used him had I needed just a cable, but I needed a PMD too, and didn't want the hassle of buying from 2 different vendors - if I had, I can imagine them both saying "my parts not bad, the other part is" - I avoided that trouble, and I'm glad I did, since the cable was bad.
Tookie said:And if we get good service from ANYBODY, we should be able to tell others
about it, or we'll end up like the other forum.
(Maybe we could have a section for this?)
Tookie said:Leroy, you should consider selling PMDs, most people that relocate are
needing one and would like a single source. The D-techs are ultra cheap.
Black smoke usually turbo related issue. Perhaps a vacuum line got disturbed?
4.3 Diesel ???? or gasser
I just replaced the lines and the soleniod, because I had that problem before,also changed the egr soleniods too. I dont think I hear thre turbo wind up like it used to.
codes 18, 32, 33
gasser
