About the the holes being smaller sized,
My knowledge of metal work is limited. But the more you work any metal the worse the hardening and brittleness gets. So if you have a simple drill bit that has a depth stop, like a drill press pre adjusted for instance, so you could take out that material in one pass- you may have no ill affects of added brittleness.
But look how small the amount to remove is. Less than 0.010 . If someone has never tried drilling a sliver of material like that in deep material- what happens is the drill bit tends to go in like a cork screw into a cork plug if at all. Then the edge of the bit actually gets wiped out. Most often the little corner tips of the drill bit just instantly dulls and it never penetrates.
So a cut like this gets done on a bridge port mill or similar with a carbide edge to enlarge the hole, which is where the work hardening happens. The engine builder and the machinist that I was speaking to a out this are the old school guys that learned the best way is the only way mentality. But I can’t help but think there has to be another option.
Simple constant flow of cold water and using a tiny sand paper type flapper wheel or roll paper wheel like used for head porting. Maybe work it for 15 seconds a hole then move to the next one. Then a rest period before doing them all again?
The engine builder friend pointed out the known cracking main web issues and asked a question- any difference in the tiny amount of metal and them not cracking?
Coincidence I am sure, but 2 of the larger hole blocks did crack, 1 GM and 1 GEP. While the 6.2, a GM 6.5 and my GEP none a cracked and won’t fit the studs. But after 3 minutes talking about it, all 3 of us agreed there is no way an additional sliver of material, 0.001 in some holes, could help anything.
We really think it is just simple tool wear on the assembly line or slight variation in bit diameter that makes the difference in if they fit or not.
Look at the tolerance ARP has in the final OD (outside dimension) of shank. A 0.002 range fo both 10mm and 12mm. The 12mm for instance is 0.469-0.471.
And the range of clearances in my block alone for
My 12mm holes:
Front driver 0.468 0.467 0.470 0.467 0.465
Front passenger 0.470 0.465 0.472 0464 0.469
(Hope those stay lined up like I typed them)
Notice passenger side cap 3. If I had screwed a stud in that one first, it would have fit all the way in barely.
But what happens when the block heats up faster than the stud? That .001 will close in and hold the edges of the stud transferring the vibrational load to the danger zone for cracking! All the cap walking forces would be amplified right there. And mainweb 3!?! The most crank and block flex right there. So the one spot I could “help” with a stud could turn to the worst possible scenario and increase the chances of cracking as pointed out to me by the engine builder.
So how big a hole? I don't know. Need to learn.
Give or take, 0.480- 0.490 is the range In the other blocks. 0.010 - 0.020. So we know not to remove excess material in any hole is best. There is a growth rate for cast, so I need to find the chart- I could swear I remember seeing one on a wall poster at a place I worked back in the day.
I also want to verify or dispell my thought of hole finishing. I was thinking because this is such a crack prone area, I know when chamfering the tip of the hole, you do it with a large drill bit, chamfer bit, counter sink bit, etc. then use some emery cloth coned around your fingertip and a quick polish to it afterwards.
So when enlarging holes should I “finish it” with emery cloth or fine sandpaper to remove scratching? It is the rough and sharp edges that you always remove for helping eliminate cracking anywhere.
The conversation with the other guys, machinist and builder, when I got into “what if I open the holes” they just shut down. I know them well enough it is their personality that does it. So I get no where with them on this line. When I ask, well what is the best way to finish a hole for not cracking the response was- “Just smash it with a sledgehammer, you aren’t doing it right anyways!”
Both of their opinion is its a wrong engine in a wrong truck anyways - they both suck. Buy a Honda and move on. So here is where I am stuck and asking for knowledge from everyone out there.
I can’t help but think there is an intelligent, affordable way to open the holes and clear the studs shanks. Not just for me right now, but everyone else that builds afterwards. If we determine that say 0.012 clearance is needed then a simple measure your studs, measure your holes and match up is good. And maybe make a roll sander of emery cloth or 600 grit paper or Something and spend 5 minutes a hole to help a little bit more to fight cracking.
Theories or charts anyone?
