this my answer to a problem i have with spilling fuel, additives, oil, etc. you can use towels/rags
but the fuel always seems to get somewhere, here it is on the side.
i looked up funnels and came across some good ones but prices were out of my range, $30.00 each plus shipping. there is also the makeshift style,
the kind that tilts and rocks when liquids are poured in along the edge instead the center. there is also the slow pour/flow rate where arms get tired from holding multiple jugs for minutes that seem to turn into hours. i have several 15 gallon barrels that i like to use, they are easy to move, load, fill, etc, without the use of anything but a strong back. since i needed a way to fill them, no cash to spend and a lot of barrels, i used the barrels themselves. money spent was $5.00 with enough pipe to make 2.
cut barrel about 8" at the top, used circular saw. cut same from middle, use remaining bottom for another project. using heatgun, soften edge of one half of middle section and slip it on the top that has been turned to around to form a funnel. looks to hold 3 gallons. when cool, drill 8 holes in a way that the 2 pieces will be held together mechanically, i used stainless hardware, each has screw/2 washers/nut.
the inside will have enough screw/bolt to hold a screen that will have a mesh filter on top, using stainless again. screw 2" pvc connector with slip fit pipe end,
cut 12" pipe length desired,
slip together, i used no cement.
heat/soften bottom of funnel slipping it over a barrel,
heating and slipping screwdrivers, allen wrenches, torx drivers,
anything that will pull it away from barrel. when enough are in place, cool with water using water hose. when cool, remove screwdrivers. funnel will look like this
and will slip over your barrel with a tight fit and not slip off and best of all, no more spils.
any questions, ask. i will use this when i mix my fuel, wvo/RUG/cetane boost/kerosene.
