SmithvilleD
Active Member
Guesstimate at this point would be possibly up to 20 psi. For our IDI 6.5 spinning a bit above 3000 rpm, 300 hp worth of mass airflow is in that general area with an IC efficient enough to keep charge temps under control to maximize charge air density.
Not expecting to go above a 20 psi limit, if even that. The plan is use the upcoming Fleece Perf VGT controller to try different boost levels under different conditions & data log the results. Then study the data/logs, to develop what the best boost level (for efficiency, power/performance, or both) is for important operating points like WOT/acceleration, WOT/or steady hard pull, highway cruise, etc.
My understanding is the controller will have programmable table(s), so you can tailor the curve to the specific engine/turbo/fueling curve setup. I'd like to idealize the air/fuel curve throughout the range up to the practical fueling limit my DS4 pump can provide w/ performance chip PCM parameters. So far, the consensus sounds like 275 - 285 honest flywheel hp @ 3200 is a conservative & realistic goal.
I'm not really interested in pushing the 6.5 max performance envelope - expect there's too much breakage in that learning curve for a guy my age. If I can build it to consistently make 280 hp w/ better than stock drivability, & 200k mile durability, that's great.
