@WarWagon what's your thoughts on the pressure readings? it cooling good now, and my trip to work this morning it got down to 40 but it was about 76 outside this morning.
And post it here!!Once I do figure out the exact charge amount I will make myself a label using the circut machine and stick it somewhere under the hood were it doesn't get removed with a replaced part like GM did. that is if I can't order the factory one it had!
There is, it shows 36 oz for the crew cab. but for what ever reason ever since I have been able to get the AC working it has always has what seemed to be low pressures on both the low and hi sides compared to temps. that's what has me scratching my head, something isn't jiving. and without a way to weigh the amount going in I'm shooting in the dark relying on what the can volume is. every other vehicle I have done in the past I have never had this much issue with as far as the pressures to temp are concerned. not to mention the R4 is very temperamental with a low charge and oil starvation!!!There should be website who specify how much refrigerant is needed.
As for the low pressure switch, I am not sure if they are even ACDelco anymore.
I think the brand is Four Seasons who are the makers of AC components for this truck.
IMO, in TX, it is probably worth having a good AC Shop do the installation or even evacuate-recharge.
This truck took a lot of refrigerant and the Suburban used even more.
The challenge with cans is that you will loose some every time you hook a new can and unhook the old one.
I paid around $1000 15 years ago.
I think if you need a new compressor, that is when you can retrofit the Sanden.
IIRC, from Thefermenator post, Sanden compressor needs less refrigerant.
if the condenser temp agrees with the pressure, maybe increasing the charge from 36 oz to a total of 40 oz might be the ticket.
If you look up the orifice tube for an early 90's model it shows the same one as the late 90's does. to me that doesn't make any sense!
Use a shop vac with a 3/4" heater hose taped on the vacuum hose to suck the junk out of the evap first.
I see my recirculate door is back to randomly opening and closing again
I had pulled it the other day and swapped the big gear out inside. but didn't think about the circuitry. It worked when I tested after doing that. maybe with this heat (106 yesterday) it's going funky. I was curious if the control board that's in behind the knobs in the dash could do this. back when I first got the ac working, I had to pull it and do a hill billy repair due to the ac push button switch not activating the compressor. plus glue the blower switch on after all the attachments were broken off! I wasn't going to spend $100 on that thing lolOnly because it's a real PIA to get the screws out: the recirculate door motor itself is the problem. Either it's a broken gear, broken gear slipping on the shaft, or one of the pots in the board is going bad. Our 1995 Yukon would have the door flop open at freeway speed and re-close slowing down. I could push it open with my hand. The motor was running like crazy trying to close it but the gear was just slipping on the shaft.
