Yeah X2. I knew you said you'd been in the hospital, but didn't know it was a stroke. Get well.I'm glad to hear you're doing well and thank you for your service
It did Leroy. My neighbor finally agreed to build a new fence between us. His first in his 70 years.Did hell just freeze over!!? Damn never thought you get rid of it. Do you get visitation rights?
That's funny, I was just getting ready to post this morning!n8in8or: Any late breaking on that build, or?
Right now I'm only running 16-17psi, but I can reach that with just over half throttle. In a few hundred miles I'll install the electronic boost controller so I can turn it up and down from inside the truck. I'm guessing I'll be running 25+ pounds of boost. I have an extra port in my manifold so I'd like to run a drive pressure gauge too, to see what it's doing on that side of the turbo.CarCode once you get use to it can force the change offset w/o moving pump.
Sounds good what boost levels are you running? I'm going to 23/25 lbs on gauge & 37.7 to 39.7 actual because I get lots of black smoke when I stand on it.
You can monitor your IAT, FT, TFT etc through CarCode.
THANKS! I was looking for that on Saturday when I couldn't find it in Car Code, but I couldn't find that online with my phone.here's Quomack's write up.
The power out of these trucks is amazing. And reliability. My dad has an 05 and its a big reason I upgraded.
It's been great talking to you and everyone else on here. This place is the reason I was able to do all I did to my rig. I bought it not knowing a thing.
I will be around. I don't know as much as you or most others here about these old trucks but I am here to offer my advice when its needed. I still brows here often, more so now on the duramax side. I have not lost any love for the 6.5. And hopefully one day I'll be in a place to venture down the old IDI road again.
At 25.7 psi you should right on the money w/compressor @ 2.75 pressure ratio do you have max fuel tuned in up on top and rev limiter raised too?Right now I'm only running 16-17psi, but I can reach that with just over half throttle. In a few hundred miles I'll install the electronic boost controller so I can turn it up and down from inside the truck. I'm guessing I'll be running 25+ pounds of boost. I have an extra port in my manifold so I'd like to run a drive pressure gauge too, to see what it's doing on that side of the turbo.
Bill said he'd give me all the fuel the pump could give so I should be maxed out. Not sure on the rev limiter yet, we'll see....At 25.7 psi you should right on the money w/compressor @ 2.75 pressure ratio do you have max fuel tuned in up on top and rev limiter raised too?
I actually prefer the 6.5 over the Duramax and am burned out on GM over cooling issues. I will say I love the Electronically controlled clutch fan on my 2003 5.9 Dodge. (I don't like the expensive parts.)
The 2005's unpredictable throttle would be a big reason to stay away from the Duramax. I preferred my 1993 over the 2005 every time. Power isn't any good if you can't control it or keep it cool. Even worse is ole patch would outrun it towing in the mountains because the 2005 overheated. The video the fellow did of his 2005 of being outrun by a 1993 Dodge is no joke. In 121 degree weather, intake mouthpiece replaced, better tune, windows down, heater on high, and still having to pull off the side of the road. Not only was the situation turning into survival I wanted the 1993 because it already did the same stuff with the AC on no issues. The 2008 Duramax we had was a lot more refined than the 2005 even with emissions, but, even it ran hot by holding 6th too long on a grade.
Hopefully the 2006 is less touchy on the throttle.
Huh, I didn't realize the recommended redline for the P400 was so low. Interesting.Rev limit on the P-400 is 3,400, so might want to work with that I had KOJO set my de-fuel at 3,300 as the code does not allow 3,400 (IIRC the choices were 3,300 or next of 3,600).
My 06 is much better than my fathers 05 in that department. I did the 06 intake upgrade and maf reflash on my dads rig and that helped/stopped his overheating problems. I am sure he doesn't tow as heavy as you do though. My old truck did great towing considering what was done but I found myself on the side of the road a few times climbing canyons. I will be leaving my 06 stock height and not doing too much to the suspension or gearing. Mainly just reliable and go fast parts. My 97 would give my dads 05 a run for his money though. It was always fun to give him crap for keeping up with his truck all the while getting better MPG's in a truck 8 years older than his.
Look at it this way the diesel does it all in half +- the rpm range as a gasser would.Huh, I didn't realize the recommended redline for the P400 was so low. Interesting.
I'm interested in your electronic boost controller does it use the gm boost control solenoid, or?Right now I'm only running 16-17psi, but I can reach that with just over half throttle. In a few hundred miles I'll install the electronic boost controller so I can turn it up and down from inside the truck. I'm guessing I'll be running 25+ pounds of boost. I have an extra port in my manifold so I'd like to run a drive pressure gauge too, to see what it's doing on that side of the turbo.
What it is, is an electronically controlled solenoid that gets plumbed into the pressure line between the compressor housing and the wastegate actuator. Because of this it intercepts the boost signal to the wastegate actuator. There's a control module that monitors boost pressure and with a knob you can variably set the boost pressure that the solenoid opens and lets the boost pressure force the wastegate actuator open. The bottom limit of the boost pressure you'll have is the one that the actuator is set to, but the upper limit is variable based on how the boost controller is set.I'm interested in your electronic boost controller does it use the gm boost control solenoid, or?
I remember JK saying something to the effect that GM's boost solenoid works better for controlling the 6.5td boost w/OBD2 but I never tried it because I ditched the vac pump early on and went to the turbo master. I know Ford's electric vac pump is a good replacement for the GM mech one.
