n8in8or
Thanks SSCan't wait to see the results. Fingers crossed for you Nate.
Yeah a guy in the IT department at work is going to look at my old laptop for me to see if it will run well enough for Car Code. That way I can set it all myselfSet the timing and TDCO sooner than later. The rate of 2 stroke is max 1 oz per gal diesel or 3 times that amount per gal kerosene, jet etc.
So you will not have to worry just datalog and adjust if need be remember whip any codes before any new setting or it will not take.Yeah a guy in the IT department at work is going to look at my old laptop for me to see if it will run well enough for Car Code. That way I can set it all myself
1oz per gallon, got it thanks![]()
Ok, thanks! I can't wait to have such a powerful tool in my arsenal.So you will not have to worry just datalog and adjust if need be remember whip any codes before any new setting or it will not take.
Can't wait to hear that badboy roar!
This made sense to me Jay....at least I would know if the pump was way off so I could take care of it immediately by manually moving it and using trial-and-error.X2
Or more specifically, set the KOKO TDCO re-learn now (rather than later) to make sure that the IP is at least within acceptable range. After setting the TDCO re-learn, the ECM will immediately code if the IP is out of range and then just correct the IP's mounting.
So I guess it is now further away from -1.94?
. . . during lunch I did the KOKO procedure. . . . it did seem even smoother after.. . . it is now though is a bit lazier and smokier.
I'm starting to feel that whatever miss/shake/whatever I have is cam and/or precup related. It's not terrible now by any means . . .
Meh . . . I am not sold that going after -1.94 in an OBD II system is worthwhile as the timing is dynamic; specifically the ECM will use data tables will control the situation anyway. But then again, perhaps I am missing something...
Regarding the TDCO and OBD-II, am open to correction by the better experts . . . As I understand OBD-II and injection timing, the TDCO (as reported by the ECM) is the physical location of the IP's mounting. When triggering the TDCO re-learn, the ECM 're-discovers' the actual (physical) position of the IP and from there continually adjusts timing (according to data tables) via the stepper motor. So, the ECM actually controls the timing and uses the physical IP orientation as a reference point.
Back to the smoke . . . Am leaning toward the tune as the ECM is possibly commanding too much fuel or the data tables are too retarded. Possible that there is an air restriction, but doubt it given all the work.
Took a look back a the earlier parts of the thread; was this motor originally N/A?
I lied. I also filled up and put 2 stroke oil in the tank. I put 24 ounces of 2-stroke oil in and 25 gallons of diesel. So the TDCO Relearn AND the 2 stroke oil are 2 things that changed during my lunch.Yeah, I don't know how it works exactly either, but if it is a rediscovery thing and tells the pump where it is, then it looks like it just rediscovered that the pump is slightly more retarded than it was before. And then by manipulating the TDCO value in the PCM, you can essentially advance or retard the injection timing electronically rather than having to physically move the pump, right? That sounds reasonable to me.
The only point I'm making about the smoke is that it is smokier after my lunch than it was before my lunch, and the only thing that changed during my lunch was doing the TDCO relearn. It is also quieter, which also sounds like it's more retarded.
Yes, it was originally N/A, but I had the precups machined to Diamond+ specs.
The 2 stroke will not make smoke as it burns at the same rates as the diesel while it does smoke in 2 stroke gas motors because of different burn rates.
More smoke after lunch maybe cold temp fueling under 170 deg.f
Lots of smoke maybe excessive fueling issue try and crank boost some to see if it dissipates.
Fuel solenoid at 90 deg off horizontal is the starting point if all else is good like timing chain etc.
I don't remember if you run gear drive for timing this type of drive has 2 deg advance built into it -1.85/-1.87 TDCO is max recommended.
Oh I'm sorry....the excessive smoke is until the turbo lights, once it's lit it's just a haze. It just seems to be taking longer to light.
It's pretty darn close to 90 if it isn't right on. I'm running the timing chain that came on the Optimizer because it was still tight.
I could try that, but it's actually 70*F here today! So I don't think it's freezing.Pull the air-filter and try it to see if the turbo lights sooner the reason I suggest this is that the filter you are using has a water resistant membrane any moisture can freeze causing a restriction and less air would make more smoke.
