When can I drop my dually off for you to put a Duramax in it for me?
I don't think there is enough money in the world to pay me to do another swap like this one. This thing has kicked my but more times than I want to even think about. In hinesight I would have done several things differently though to have made it an easier swap, but it's too late now.
Got one more bug figured out this morning. WONDERFUL ALLDATA got me again. I charged the A/C but the compressor wouldn't turn on. I dug up everything I could from ALLDATA about the A/C trigger and it clearly said that it looks for a ground from the A/C control head to trigger the compressor, THIS IS FALSE! It looks for a 12V+ signal to trigger the compressor to come on. So now I have to go back into my PDC and remove the A/C request relay and hook the A/C sense wire up to my A/C request wire from the 95 head since it powers the circuit on.
I did have power to em when I checked em, and the TCM does scan now with EFILIVE. I'm on my honeymoon right now though, so i won't be back till the 21st or 22nd. I'm pretty sure I got 2 bad injectors though as 7 was a little high for the balance rate, and #1 is right on the edge to going over. When I shut those 2 down the engine ran fine except for the miss from the 3 cylinders being shut off. All the fun of doing a big project like this one I guess.Does your TCM have power? I had a problem with that. It ran like crap like you were describing, it makes the engine and trans roll over hard. The fuse goes in the drivers fuse box. I would check the circuits that go inside the truck. I'll look at my helms tomorrow, i have it highlighted....
Aftermarket injectors = bad news. That's good to know for everyone but you! You didn't really need that...
Genuine GM stuff can be worth the price!!
Have you tried swapping them with another "hole" to see if it is the injectors.
