tim6.5
I have a 95 k 3500 single wheel with a 6.5 turbo 4l80e. It wont go over 53mph if I try it shifts to neutral. Dtcs 73 81 82 83 87 fluid clean no material. In pan what do I do only has 116,286 miles
i changed both solenoids a/b cleaned grounds still doing same thing i gonna check and clean the main plug on side of trans what wire should i check for power i dont have access to a scanner mine was stolen thanks for all the feedback
yes i have 3rd gear
Pin "E"(IIRC the letters are on the back side of the plug), has 12v+ with key on. Its the only pin on that row(4 rows) in the plug. Dont think this is your problem, without power you would only have 2nd/R.
I'd check out the TOSS sensor, I dont know the ohms off the top of my head, think it ohms the same as the TISS(trans input speed sensor) in the front drivers side of the trans(two wire plug).
