Odlaw
Redneck
If you're on a budget, harbor freight now carries these http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=98478
I removed one from the box in the store and was surprised at the quality. It appears to be identical to my Faze boost/vac gauge except it has the option of 7 different lighting colors and the markings are much easier to read at a glance.
I paid $40.00 for mine - this is a steal at $14.99 assuming it works good.
Regarding hearing the turbo. My little GM-3 was silent with factory airbox and exhaust even with homemade turbo master and 10 psi of boost. Installed a 3.5 " straight piped, no kitty or muffler to the rear axle and 4" out behind RR wheel. I could hear the whistle from the cab when shifting- around 1800-2000 rpm - would whistle at the top of spool up and at the start of spool down. After I added a cone filter(the type that has dual cones, one inverted in the end of the filter) - now I can here the turbo at around 1,200 rpm all the way up. It's not obnoxious, just a nice turbine sound from under the hood and the same whistle out the tail pipe.
As stated above, you're at the right place for the best 6.5 knowledge base on the net....or anywhere for that matter.
Welcome aboard!
Smitty
Welcome aboard!
Smitty
