Bubbasavage44
- Messages
- 1
- Reaction score
- 1
94chevy 4l80e 4x4 what other years interchangeable with
Can I use a transmission from a 2003 in my 94 k2500?
I would have your 94 rebuiltCan I use a transmission from a 2003 in my 94 k2500?
Is there a conversion kit for this project?Welcome to the forum @Paul Bunyan as Ferm stated above some of the differences, there are internal differences on the valve body and in the internal harness. it might work by swapping out the internal harness and sensors / solenoids under the pan along with the shift shaft, but I'm no expert.
you can also make it work as is by only swapping out the shift shaft for the linkage to work and going with a stand alone trans controller like the EZ-TCI TCU. others make controllers as well. it all depends on what your budget is. be advised that depending on what engine your 94 has and what the donor had makes a difference on needing to replace the torque converter or not. Do not plan on re-using your old TC if your old trans burnt up. the best route by far is to have YOURS rebuilt and not exchanged.
I found a transmission for my 94 2500 2wheel drive. The only problem is it's out of a 4×4. How much trouble will it be to put it in my puckup?94 is a 1 year only. That said, if you swap your shift shaft, a 95-96 will directly swap in. 95-96 is the same trans, but they use a longer shift shaft meant for a shift cable connection instead of the mechanical linkage connection and have a nsbu switch to operate the cluster gear display, reverse lights, and starter nuetr safety switch. Do not swap in a 91-93, even if the plug is the same, they have internal differences.
