Acesneights1
He said replaced in 04.Kenny
The Fuel solenoid in the IP may be sticking due to some galling.
Try a heavy load of tranny oil in the tank. Maybe a gallon and see if the issue abates some.
If the problem gets better then its probably an issue in the IP with the Fuel solenoid hanging up.
The fuel solenoid moves in its bore one helluvalot.
This is a delicate ballancing act with the ECM checking and rechecking settings and adjusting the solenoid.
The solenoid is constantly moving and any galling or roughness will wreak havoc with the way it works.
Any crap or water over time will ruin the delicate parts.
A 2 micron filter IMHO is the best choice, along with a large collection bowl that can be seen easily.
Water will ruin these things in short order.
The lack of lube in the new ULSD also does not help either.
How much time on the IP ????
MGW
