88gmctruck
02GMCtruck
Well, here is the update from today. We got the trans shift linkage all worked up. For those who have asked how my linkage is, here is the best picture ever: outside of the truck. Basically all that is done is to move the arm over via a longer pivot point. It has a stepped portion to clear the trans as well. Obviously the pass side has to be supported of the trans.
I got the floor cut for the shifter, as well as an additional hole to make the install MUCH easier. When we too the trans from the parts rig the shift tower was so tall that we kept getting hung up on the trans tunnel, and ended up just pulling the sheetmetal back. I decided then I'd make another hole and build a screw on cover for it, that way the trans can slide right in.
Then we got the trans on a chunk of wood and strapped it to the floor jack. Don't want 200lbs of cast iron falling on you.
After it's in. :thumbsup:
While dad put the drivelines and stuff back, I worked on the interior side of things. Once the trans was in place I located the shifter trim ring, drilled the holes and bolted it together. After everything fit, I put the carpet back and started the re-assembly of everything else: Trim, Dash, I/P, seat, etc.
This is what the interior now looks like with two sticks
Notice the new (and much more awkward and annoying) location of the cupholders.
Then, the test drive. First problem I encountered was the speedo/cruise not working and my brake warning light was stuck on. After about and hour of thinking, switching the speed sensor, etc, I realized the RWAL (rear wheel antilock) and speedo share a fuse. While I was wrestling the wiring around I must have dislodged it...... :mad2: But yeah, whats a project without a challenge. So after that, on to screwing around in it. Oh it's fun. Way too fun. Trans shifts great, syncros work flawlessly, etc. 1st gear is a beast, particularly in low range. I can't want to go play offroad. I also got it up to freeway speeds, also worked great. It's definatly noticable there is a manual down there, but only if your actually paying attention to it. After driving around for about 45mins the trans was up around 140 degrees if anyone was wondering.
All in all, everything works great, and the swap went very smoothly (no trips to the part store, nothing broken, etc). I'll be driving it around some more tomorrow, can't wait. As of now, the only thing left to give away this truck was originally an automatic is the steering column, but that will be changed eventually.
